62chevystepside said:
Yes I took the drive gear off of the shaft.
I took the timing cover off and looked at the three plugs, they arn't leaking. SO it must be a rear one , I'm just going to have to take it back to the machine shop, and the can fix there problem
If the rear plug was leaking, you'd know it as this would drain into the bell-housing and would pour out the bottom.
It is not uncommon for the left side, especially, to be slow in feeding the rockers. The average electric drill doesn't have the kahunas to turn the pump fast enough to overcome the leakage thru the clearances, the left side is numeral lasto on the oiling scheme larglely because the distributor housing does not make an oil tight seal when it caps the left side galley. So it takes a lot of performance from a drill motor to spin the pump to where it overcomes all the lubrication system's internal leakage. Plus when using hydraulics, they often won't feed the push-rods unless the engine is being rotated.
By in-large, I don't think you have a problem.
