383 kit
Callies Dragon Slayer crank(complete kit)
JE SRP pistons
C&A Rings
CL 77 Bearings
Assembly & Balance $2,200
1 Dart Block $1,650
1 Cloyes True Set $85
1 GM timing chain cover $20
set cam bolts $10
1 timing chain $28
1 Damper ATI $275
1 moroso pan 7qts $195
1 moroso pick up $35
1 melling z28 pump $38
Gaskets complete fel pro set $120
Hydrolic roller cam $259
Hydrloi roller lifters(CC 885) $475
magnum lifters
Brass cam gear shim $ 6
Total parts $5,396
Block:
Boil $120
instal cam bearings
Square deck $110
Bore and Hone - Fit hone
With plate $175
Notch for 383 $175
Total Parts and Labor $6,396
This also includes assembly of using my AFR heads, intake and carb. Ready to drop in motor.
JE SRP pistons
C&A Rings
CL 77 Bearings
1 Dart Block $1,650
set cam bolts $10
1 timing chain $28
1 Damper ATI $275
magnum lifters
Total parts $5,396
Block:
Boil $120
instal cam bearings
Square deck $110
With plate $175
Notch for 383 $175
