If you have an older car, the headlight current runs up through the dashboard, though the lighting switch, then back out to the headlights. That's a lot of wire to travel through, and the factory tended to use wire that was a gauge (or two) too small. Not only does this dim your headlights, it dims your dash lights as they "fight" for the available current.
I just did a conversion where the headlight switch now activates a relay that sends current to the headlights using only 12 and 14 gauge wire. To be "stealthy" I put the relays in the voltage regulator that is not longer used after switching to a 1-wire alternator.
The results are that the brightness of the low beams
literally doubled and the high beams got ~67% brighter as monitored using the light meter in my Nikon.
These same increases in headlight performance are documented elsewhere.
