Installing a GM 350/350 in an old Volvo. Previously had a 283 with standard 15"x15" radiator. Engine would heat up in 95 degree ambient..but did not boil over (always shut down and cooled before continuing on)
Currently modifying the installation and will have a 20" x 15" radiator in front and am considering using a remote radiator mounted under the rear of the vehicle (gas tank is now in trunk) with cooling fans etc.
Mounted a IMSA Mazda rotart in a 914 years back and used exhaust tubes to route water to radiator in front. Worked OK. Only problem being that the engine was spinning 8000 much of the time and did not reduce size of the water pump pulley.
Would like input on running two radiators in the Volvo.
Thanks.......Al Padur........Reno
