My distributor was leaking oil I removed the distributor from my Chevy 350 and replaced the gasket I put it back in the same place I took it out lined it up with the #1 plug and damper at tdc, it wont start it keeps popping out of the carb, I though it might be a tooth off so I had a friend crank the engine to get it at tdc , he left the key on , I didn,t know he left it on and started to pull the distributor ---there was a spark and some black smoke I guess I must of hit something or did the modular burn out? any way It wont start now!! :: just keeps popping threw the carb, could it be 180 degrees out ?
It has a flame thrower distributor hei how do you check the modular?
