I want to remove my transmission: I can remove the sparkplugs; detach the coil wire to distributor; use a push button jumper starter switch (S post to battery positive) to rotate the flexplate(flywheel) and see the 3 bolts holding the flexplate to converter through the little oval inspection hole to the right of the starter. I know I can rotate the engine this way. This would allow me to loosen and remove the 3 bolts with a 9/16 inch socket. I could mark the 3 bolts and flexplate holes to insure the same re-assembly of each bolt to its respective bolt-hole. However, how does one mark the corresponding three converter nuts which are behind the flexplate to insure the same re-assembly of bolt to nut?.
I have seen an advertised and pictured "flexplate (flywheel) turner tool" which is advertised to turn a flywheel (to use in removing the 3 bolts). It seems like removing the starter would be a requirement to even think about doing this. With the starter removed, there is an starter opening hole about 4 inches in diameter where one can see the flywheel teeth. That pictured flywheel tool seems too big to use in that starter opening hole. Does anyone have any comments about this tool with respect to the starter hole opening? Can it even be used there?
I've also seen sites and threads where people have recommended a flat blade tip screw driver that can be used to turn a flywheel to see and remove the 3 bolts. One adviser from another site said: "with plugs removed a screw driver angled in the bottom hole in the flywheel extension housing will allow you to turn the engine a little at a time. You can also turn the engine with the fan blade on the top side by pushing down on one side of the fan belt." The referenced bottom hole looks like a drain hole (half inch) just ahead of the actual transmission drain plug. I can't get that fan blade approach to rotate the engine yet. I also haven't gotten that screwdriver approach to rotate anything.
What am I missing? Does anyone have any more experience or advice about using this special flywheel tool or using the long flat blade tip screw driver technique or even using the fan blade approach? Is the flywheel tool even applicable in the starter hole opening? Could these techniques be engine size dependent?
Thanks in advance.
Thanks in advance.
