So i am in the process of swapping a v8 into my 92 s10 4X4, well the new transmission i got will not work with the 4X4 so i am removing it, i did some research and found that it is safe to remove the front differential and take apart the cv axles as long as you have the threaded piece in the wheel bearing, this is true right?
The engine will be removed within the next week or so, so i am going to remove the front differential while the engine is out
So what is the best way to go about removing the front differential, with the engine out? i would imagine start by removing the cv axles then unbolt the differential and lift it out? i have never removed cv axles before, could someone explain how it is done? i removed the bolts on one side at the part where the cv axle bolts to the differential but it wont budge, did i forget something?
First time doing this, and thank you in advance for any help
