I have it unbolted with a trans jack under just could not get it to come down because it's hitting up there and yes I did remove the shifter so as I expected I have to remove carpet and seat to remove tunnel hump?If it’s the stock trans then you need to remove the seat and unbolt the tunnel hump.
shifter needs removed. IIRC you push the stick down into the trans and turn it 90 degrees to the left.
Use an engine crane extended into the cab to hold/lift the trans and unbolt the trans from the bellhousing. top Two bolts easy to see, bottom 2 are in the bellhousing. Need to remove inspection plate for bolt access.
slide trans back and down to floor.
o great so much for people saying easier to remove manual transmission sI’m afraid so!
Well there she went thanks my manSome are!
I’ve done the 3 speed bench press many times. Cast iron 100 lb ones were always extra grunt.
needing to remove seat and hump is preferred method. Hackers just cut more room in the hump. Seen that many times.
You'll be surprised by this, but it really works....pack the cavity with bread..yes, good old white or wheat bread or a burger bun, .....and drive a close fitting dowel or rod into it....the bread will compress and hydraulic and push the bearing out....with a lot less mess than doing it with axle grease.Well unfortunately I had enough today the dang pilot bearing does not want to come out
Tried the bread and grease andit ain't giving . I like your other waythread the ID with a 5/8-11 TPI tap and used a bolt to jack screw it out. Try it later tonight or tomorrowYou'll be surprised by this, but it really works....pack the cavity with bread..yes, good old white or wheat bread or a burger bun, .....and drive a close fitting dowel or rod into it....the bread will compress and hydraulic and push the bearing out....with a lot less mess than doing it with axle grease.
J
Or thread the ID with a 5/8-11 TPI tap and used a bolt to jack screw it out.
