1 - 9 of 9 Posts
Anyone out there have any input on steel body repair panels. I've got a '71 GMC 3/4 ton Fleetside and I need to repair both rocker panels and the lower left rear section of the cab. The rocker panels are the main concern. I've looked around, LMC, J.C. Whitney and some other online places. Other than that the truck is pretty solid. Also any ideas on attaching these panels?? I'm tryin' to finish this up before a trip to Iraqistan. <img src="graemlins/boxing.gif" border="0" alt="[boxing]" />
try www.raybuck.com
I was at raybuck.com and they have a good selection so they may have it. If not then try search engines such as search.com and google.com. Search.com sometimes lists more info than google.
A tip.....just enter the words " rocker panels" maybe even add the name and year of your vehicle. Try different things when entering a topic cause it can get you different results if it doesnt get you what you want the first time. Search engines can be tricky that way. Hope this helps.
1 - 9 of 9 Posts
