Hey new to the forum here. Rebuilding my 2nd 4l60. While Air testing the reverse drum, I have leakage past the stator rings. The piston will apply but it leaks quite a bit. Is this acceptable for scarf cut rings. I used them on my other build and they did not leak but they do on this one. Reverse drum is in good shape were the rings seal. I ordered some solid ones just incase. I heard that a bit of leakage is ok since air can get by the rings better than the thick atf.
Discussion Starter #3
Fill the circuit with fluid then air test it.
Hey bud thanks for the responce. I tested with fluid and the reverse drum jumped up off the stator. Piston engaged a lot stronger at 100psi testing. As psi went down it would still engage but I could see and hear leakage right at the reverse drum bushing. You think It would be ok? I mean it seems ok even with the leakage. It still engages the clutches nice and strong.
