I'm currently reviving a 1968 Corvette 350 cu.in 300 H.P. It currently has a TH400 transmission installed which shifts perfectly, but does not have the Overdrive gear or the Torque Converter Lockup.
I have already modified a TH700R4 for my 1934 SBC 350 cu.in. street truck, and it has shifted perfectly.
I realize I can install a base 4L60 or a TH700R4 with no problem, but I can get a great deal on a 4L60E.
Also, the 4L60E has the gear ratio I would like to have in the Vette, which only weighs 3500 lbs.
There are dozens of internet videos about converting the 4L60E to be shifted Manually by rewiring it for a floor shifter, but no one has been able to solve the EPC Force Motor rewiring problem.
THE MAIN REASON FOR REWIRING THE 4L6OE Force Motor so it will Operate correctly IS TO AVOID RUINING/DESTROYING THE TRANSMISSION BECAUSE OF CONSTANT FULL LINE-PRESSURE WHICH CAN LEAD TO TRANSMISSION FAILURE OVER TIME BECAUSE OF HARD SHIFTS.
Problem #1 concerning the TCC PWM Solenoid(valve) can be solved by modifying the end of the valve body or the internal orifice diameter to a larger diameter so fluid can reach the Torque Converter Clutch at a faster rate which will engage the torque converter without "slamming the clutch" into full lockup (which would happen with Full Line-Pressure)
PROBLEM #2 IS MY HOLD-UP concerning modifying the EPC Force Motor. It DOES seem to require an in-vehicle computer to operate properly because of the low-voltage/ cycle-signal it receives from the vehicle computer. which causes the Force Motor to cycle On and Off about 30 times a minute in order to control shifting pressure.
My plan is to rewire the EPC using a relay/resistor/etc to cause the EPC to function as though a in-vehicle computer is sending signals to the EPC.
MY PROBLEM is that I have limited knowledge as to how the relay/resistor/potentiometer can be wired to the EPC to make it operate correctly.
The Vette is "UNDER CONSTRUCTION" at the moment"
