So I want my car to be pretty low. Kind of like the way Troy Trepanier does it.
I watched the Rides show where he built Sick Fish (the silver cuda) and noted how he went about getting the stance of the car the way he wanted.
I set my frame up on wooden blocks on the floor. I put a 4.5in. block under the front corners of the frame (the corner right behind the front wheels) and 5in blocks under the corners just in front of the rear wheels (this is a 65 LeMans BTW)
Next I set the rearend in on blocks that hold it to the heighth that it would be if I were using 28in. tires. The rearend is just a half inch away from hitting the frame at that point so I'll have to do a C notch and gusset on the top of the frame. I'm planning on 3 inches or so of suspension compression from ride height.
I originally wanted to use a truck arm suspension but that is looking like it will be impossible with the radically low setup. I would have to use something like 4 in. lowering blocks to bolt the rearend to the arms. Not a good solution I don't think.
So now the question is where to go from here. I can't use the stock suspension (that design sucks anyway), it looks like a 4 link would intrude quite a ways into the backseat space (I want a usable back seat) and I'm not sure a 3 link would work either for the same reason. I could split the back seats and add a console but that seems like an excessive amount of work.
For a solution I'm looking at using the original lower frame mounts for the lower control arms and building a torque arm to create a 2 link torque arm rear suspension (have to add a panhard bar too of course). I'll need a crossmember for that but I was planning for that anyway for the truck arm.
Anybody have any experience building an exceptionally low car?
Any comments on my ideas?
I think it's always good to run these things past some other people for input. I'm sure I haven't thought of everything
I can post some pictures for clarification too if needed.
Thanks for any and all input. Sorry it's a long one.
Later....
Wally
Later....
Wally
