59chevyapache said:
i think i would go with the 210 cc and a nice stall and some better gears. But what about the combustion chamber size would 74cc be good with the stock pistons for what im looking for?
Yes with flattops(6cc valve reliefs) I'd go with the 74cc chambers. That'll give you approximately 9.75:1 compression. I'd consider decking the block to 0.010 - 0.015 and Fel-Pro 0.039 head gaskets to give you 0.049 - 0.054 quench, which these heads can take advantage of. May only give you 4-5 extra hp but will help with efficiency greatly. Will put you right under 10:1 compression as well. With EFI you could probably 89 octane on the street!
You can make +400hp very easy with AFR 195's, rpm air gap, headers, 9.5:1 compression and a +220* +0.480 hyd camshaft.
You can make +450 easy with AFR 195's, rpm air gap, headers, 9.5:1 compression and about the same sized hyd roller camshaft.
If I were you I'd go with the 195's instead of the 210's for several reasons.
#1 AFR doesn't call it a street head because it's not. You'll lose low end compared to the 195's and with a +3800lb truck you'll notice the lack of torque down low on the street I guarantee. More rear gear and a higher stall can fix this problem but then you're still losing fuel efficiency every time you leave a light and when cruising on the highway(you mentioned this concern).
#2 If you're not going to go with forged rods and spin 6500-7000 you're not going to get full use of the 210's. Getting full use of the 210's also means a larger cam, so again the fuel efficiency problem and emissions as well possibly(if yer truck has to do that).
#3 Take the cash you save buying the 195's over the 210's and put it towards a hydraulic roller setup. Depending on cam and compression you'll make anywhere from 450-500hp and 500lb-ft from as low as 2000rpm without a problem.
My '91 Camaro weighs 3100lbs dry and has the setup in the sig with a stock converter, 700R4 and a peg leg 2.73 rear. It's somewhat of a dog till 2000rpm and even then it doesn't even really pick up till 3500rpm IMHO. I'm running a stock crank and rods with Manley forged flattops and the only time I'll see 6000rpm is at the strip but I mostly run autox and some road racing. If you want to keep your truck a daily driver I'd highly recommend the 195's and a hyd roller setup. You'll get more power than you asked for in the first place(in the rpm range that's usuable 95% of the time) and if you think you'll want more later then go with all forged internals and put a 200hp shot of nitrous to it later on at the track. Does anyone really need more than 500hp on the street anyway?
It's easy to start getting excited about the bigger heads and bigger cams but if you want a daily driver remember to keep that in mind.
As for a converter and gears. I'd recommend 3.73's and at least a 2400rpm lockup converter. If you cruise the highway for any length of time I wouldn't go over 2600rpm but if things are close I'd go with something between 3000-3500rpm to get the most out of the motor. But then you'll still have to deal with traction
I'm assuming you have the long truck trailing arms but that'll be the only thing on your side there.
Anyway, good luck with your buildup but remember the AFR heads make awesome power without needing much cam!
