1 - 6 of 6 Posts
MERRY CHRISTMAS TO EVERY ONE .
Was woundering if any one knew what rim might fit a 2000 mustang 225-55-16R tire I am look to put a full size tire in the trunk for a spare and not spend a fortune on a new rim.If any one knows of a rim of some thing a poor boy might pick up at a junk yard please let me know.
Thanks 39 OLDROD
Hotrodders.com moderator
Take off rims
My local tire guy has take off rims from cars that he has put fancy wheels on..I suspect your local tire guy may have the same..if not check around some of the wrecking yards and they may have one for you....
OMT
It doesn't have to be a 16. Just find a common old 15 inch steel wheel off a Crown vic or something with the same pattern, get the circumference off the tires you are running and buy a 15 inch tire with the same circumference.
Spare tire
Get you a standard 4 1/5 X 5 steel 14 or 15 inch rim and put a tire on it with the same diameter as the tires you have on your car at this time. Its a lot cheaper and definately a lot cooler than driving on one of those worthless donut spares.
Since you arent going to be running it forever, you might even consider just putting a good used tire on it. I have replaced the donut spares in all my vehicles in this manner.
Your local salvage yard should be able to fix you right up. Barring that, go to a tire shop that does a lot of custom rims, as most likely they will have a stock rim and tire sitting around that would meet your needs.
I am presuming your wheels have a 4 1/2 inch bolt pattern.
You might try one of these:
98-02 Crown Victoria/Grand Marquis/Town Car and
98-01 Mountaineer
98-03 Explorer
These are 16x7" steel wheels with the correct 4 1/2" bolt pattern. Pretty unusual on the SUV's except as a full-sized spare.
On the Crown Vics expect to see them almost exclusively on police/taxi vehicles.
This might be a "try it and see" thing since SN95 Mustangs have such a deep offset fitment and these vehicles don't.
On my much older Mustang I'm carrying a 16x4" mini spare from a 94-7 Crown Vic. It was aluminum, painted black. The black was easily removed and the aluminum very buffable. It fits all four corners of my car and is a good match for the tire heaights. Plus the polished finish makes nice eye candy for the trunk. I'd prefer one from a 94-03 Mustang. The same thing but in the 17" size (nice to clear big brakes). I can't find one in the junkyards anywhere and am starting to wonder if these weren't a "Cobra only" item or something.
Thanks for all the suggestions I will be closed for the new years holidays and will ride to one of the yards and see whit I can find for a rim as I have a good tire.
HAPPY NEW YEAR YALL
LATER 39 OLDROD
1 - 6 of 6 Posts
