1 - 8 of 8 Posts
Having trouble with one of my carbs. in my 3 deuce set up, good idle and then sputters until I kick in my other two carbs. when I go with smaller jets it seems to help but my plugs don't say I'm running too rich.
Thanks for the help
Drifter
[ April 17, 2002: Message edited by: DRIFTER ]</p>
have you checked the accelerator pump make sure youve got a good stream of gas sounds like its not getting that first good dose of gas to cover up until the vacuum starts pulling from the main bleeds just a ideal
I agree with Wrenchturner. I had '61 Biscayne with (TRW)SB Chevy, Offenhauser manifold, 3 Rochester 2BBL carbs, progressive linkage. Had to bend the tang to the accelerator pump for the primary carb. Ended problem.
Thanks, I forgot to mention that I have a big cam so I do not much vacuum (about 5.5 or 6)can this be part of the problem?
Thanks
Drifter
My cam was a 3/4 race with hydraulic lifters; totally rebuilt in 1970. Everything was TRW with .030-over rings. I suspect you have an Isky with solids. I do not know the answer but I would pull the primary (middle?) carb and recheck the float level (drop) and accelerator pump operation. For that money, it's affordable to replace the acc. pump just to get a new rubber (or vinyl plunger). A properly bent tang could be everything! Good luck.
ASE Master
Hi Drifter, First thing on any multiple carb set up is to make sure the throttle plates are opening equal with a Unisyn syncronizer. If the carbs are designed to open at the same time. Otherwise it sounds like a lean run or accelerator pump problem. Try a small squirt of gas from a spray bottle into the throat as soon as it stumbles and see if it clears.If it does its a bad accel pump. Or you can look down the throat and look for the fuel squirting from a small tube along the side of the venturi everytime you accelrate it.
Thanks for the help, I'll give it a try. I'm also going to put a new power piston assembly with a weaker spring to help with the low vacuum.
Thanks
Drifter
This is regards to the door panels with carpet, try H&H Handicraft Upholsters located in Cerro Gordo, Il. 221 E.South St. 217-763-5731 ask for Tim,Tony or Montay Hyde. They are good at that kind of things.
1 - 8 of 8 Posts
