This is my first thread in the Engine Section, so please bear with me.
My brother has a '02 Monte Carlo LS, 3400 V6. He had the leaking LIMG, yesterday we tore the engine apart th replace the gasket. Found the leak, replaced the gasket and began the "rebuild". The rockers had to be loosened and the pushrods removed inorder to get the gasket changed. On rebuild the service manuals said to torque the rockers to 168 inch #'s and then rotate an additional 30 degrees. This was done correctly with a TQ wrench and TQ Angle Meter. Once the engine was fully rebuilt, we started it to hear an extremely loud clicking coming from the front valve cover. We took it off, rechecked all the TQ settings and pushrods. All were seated correctly, and the TQ was correct. Started it again, and it still clicked. My brother then called a friend of his to see if he knew what the problem was, he said the we needed to loosen the rockers, bring each piston to TDC then re-torque them. We did this. The clicking is still there, just a slight bit quiter. All pushrods were put back into their correct possition and seated in the lifter and rockers. The TQ settings are spot on.
Does anyone have any ideas on how to fix this click? My brother has to go back to school on Monday, so we need to try to figure this out quickly. Thanks guys.
Merry Christmas.
Chris
Merry Christmas.
Chris
