First let me just say this is a great fourm. Anyway..
I have a 1968 rocket 350 installed in a 1985 Cutlass Supreme. This was my first car and I did nearly all the work myself back in my 18-23 years. Now it's 10 years later and I unburied it from my garage and would like to get it running right. Here's where i'm at:
1968 Rocket 350 block
stock crank, cam, & heads.
Edelbrock Performer RPM Intake
Edelbrock 1407 750cfm carb
Stock TH400 Tranny & Torque Converter from a '77 Buick century
Headers
Hydraulic lifters, roller rockers
Factory rear from the 85 (was a 3.8 V6)
It was barely running when I pulled it out yesterday and bogged when I hit the gas. Last Night I replaced the plugs, set timing to 8 degrees, adjusted the idle A/F screws to about 1 1/2 open, changed to blue springs in the carb and set the pump rod to the bottom hole as per suggestions from other posts I found on this board and it's already a thousand times better. The problem now is it lacks power (I can't spin the tires the way I could when it was stock in the 68) And it still backfires every once in a while out both the carb and the exhaust. There is a small blowout in the header gasket from one of the backfires, but there are no other exhaust or vacuum leaks.
The distributer is HEI style with a vacuum advance and the advance line is hooked up to the proper, full-time vacuum port on the carb. I do not know what it's from but the guy I bought the 68 from said he put it in because he was sick of replacing the points. Interesting fact is that when it was on the stock engine the vacuum line was never hooked up. He said it ran better that way.
The jets in the carb are stock (.113 primary, .107 secondary)
The rods are not stock (stock was .071x.049 now .073x.052)
The rods made a difference for the better back when I put them in, but now that I'm trying to do things right I have no idea what rod/jet combination I should use. The boards say a manual comes with the kit but mine did not. I went to Edelbrock's site and they do not have it either.
I have a performer RPM camshaft that was never installed.
The stock 68 had a powerglide tranny and I used to be able to spin my tires off from start without even touching the brake. What do I have to do here to get some guts out of this thing. It's got a response similar similar to my full size van!
Thanks for your time time. I know it's a long post, but I've called around and no one locally could help me. I appreciate any and all suggestions.
Headers
