Hello
I'm thinking about buying a set of Harland 1.5 ratio roller rockers, 3/8" ARP studs, Manley guide plates, poly locks. They will be going on a 350 with Vortec heads the springs I'm using are Comp Cams 981-16, 1.250 Outer with Dampner the vortecs have had the bosses machined, I know that you need self-aligning rocker arms with vortecs but with the guide plates will I be able to get away with this setup or will i have to buy a set of self aligning roller rockers??
Thanks
Thanks
