TOM is absolutely correct. Bigger ratios can be problematic.
Depending on who did the tests, full roller rockers are good for 2-8 hp.
Most of those old style factory rockers are a little short of the 1.5 they are suppose top be, so as CompCams says, using their rockers helps because of better ratio and some friction reduction. Is $ worth the little gain?
Your best bang for the buck might be a flat tappet "pulling" cam in the 210* range. Places like Summit have an in-house brand where the "full kit" price (cam, lifters, gears) will be about the same price as the full roller rockers and might give you 25 lb ft more torque where you need it.
Don't forget to maximize what you have with a proper carb and distributor curve.
