You definitely want to get new plugs in it, once they get fouled they are junk for performance use.
I would go back to the 6.5 power valves, the O2 meter is showing pig rich at "fast cruise" because the powervalves are now open when they really don't yet need to be since you are at part throttle still.
This also corresponds with the good 12.5 AFR at WOT, since fuel delivered at WOT is from main jet and power valve feeding together as designed.
Your powervalves are now "powering" when they shouldn't be, too early... LOL
Blip of hesitation at the hit of the throttle is pump shot, as indicated by the brief sharp lean reading spike that then catches itself.
This could be either a need for a larger squirter, or it could be just a need for a quicker rate accelerator pump cam on the linkage with the current squirter.
Did you happen to notice what color pump cams your carbs have on it??
