Hello guys I have a few questions when it comes to balancing a rotating assembly. I understand the basics of what they do to get a certain bobble weight for the total assembly as they use the weight of everything added up and take off the crankshaft and stuff to balance things out.
Now I have a few questions and a year ago I was looking at getting a dart shp block done by him and also a rotating assembly done by Carl Hinkson CNC blocks Northeast. I was going to have him ship me the stuff by freight and I was limited on what my options were. I wanted to get a standard bore dart shp block along with a scat forged crankshaft and a set of forged DSS pistons 4.00 size. He said he recommended a better set of Mahle pistons that were .030 over size and I did not want my block overbore and he also recommended a certain name brand crankshaft that was forged and he said it was better then the scat but I said I preferred the scat crank. He was fine with me and the scat connecting rods I wanted.
He told me the crank was made by the same company who made the Eagle crankshafts but was not an Eagle brand and I told him I once had an Eagle crank and it had a lot of issues and I sold it before using it a it was all out of spec and I said my current build has a scat crank and it was spot on out of the box. He stated his crank he recommended was better finish etc.
I told him I did not want that rotating assembly deal and did not feel comfortable with a brand name made by Eagle and that was just my feeling but I meant nothing against him but he took it so personally that he said he would not do business with me because of that and that I questioned his abilities and offended his intelligence which I was never trying to do and just wanted what I was wanting to do for my build but he would not except what I wanted and only excepted what he wanted to do.
Anyways with all that out of the way when I talked to him I discussed that I had in my current build a set of 5.7 Scat H beam rods with a scat forged 3.480 crankshaft and Icon forged 4032 pistons and I told him that when it was balanced that they grinded some material on the bottom of the connecting rods which was very little but you could tell where they sanded some material off and he said he never has to do that and that them doing that damages the rods and affects the heat treatment and how much truth is there to that?
I am planning on hopefully if funds allow me to get my Dart shp block 4.0 bore with my scat 3.480 forged crank and the scat pro comp I beam rods 7/16 bolts this time instead of the H beam rods with a set of DSS 4320 aluminum forged pistons balanced at the machine shop who did my last build and have them do the machine work to my block with they use the torque plate hone and I am having all the works done.
My question is mainly on the balancing part. Was Carl right or was he just full of it or am I missing something here and will it hurt my connecting rods? On my previous 350 5 years back I had the current machine shop I use I had a milder build with just a set of scat 3/8 capscrew pressed connecting rods which are the step up from the through bolt design but not a floating type rod and I used a cast scat crank and a set of hyper pistons and nothing else fancy. They did not grind anything from the bottom of the rods on that one build.
From what I know the H beam rods are way heavier then the I beam rods and thus I am thinking that is why they sanded some from the bottoms. Can anybody who knows more about this fill me in on this and do I have anything to be worried about. This machine shop builds racing engines and in case anybody wants to know who they are they are called Watson Rupel racing performance in Sarahsville Ohio and they have done some awesome work on many of my stuff and also stuff my Father has worked and built for others over the years.
Thanks guys and sorry for the whole post but I just wanted to get the whole story out there as to why I question things as to what he told me and I am not overly educated on this subject.
Thanks guys and thanks for any help and information to help educate me.
