I am having a problem with my ignition system in my sbc. It is a 355 with 10.7/1 compression,a 252/260 duration @ .050 camshaft and a Holley 750 double pumper with annular boosters.The ignition system is a HEI with an in cap MSD coil,an Accel control module and Accel super comp wires.
Whenever I put new plugs in it runs great for about the first 10 minutes ,then it begins to run rough.The engine seems to stumble and the tach needle jumps around between 1000-800 rpm with the car in gear.
I pulled the plugs and they still look new and they are a nice tan color so the carburator is tuned properly. The car also seems to run great except at idle.
I plan on uprading to a complete MSD ignition. A Pro Billet distributer,6AL ignition box, blaster 2 coil and a set of MSD plug wires.
Do you think this ignition system upgrade will take care of this problem? THANKS !! Mike
