Its in a 68 Chevelle with a quadrajet carb. It runs rough under load. It starts fine and idles ok. Here is what I have done:
-Changed plugs, wires, cap, rotor, coil
-checked spark at all and getting spark at plugs
-compression check
-20 -22.5 psi
-the needle bounces a lot @ idle
-examined rocker arms and they look fine
-took a temp reading @ header inlet and #8 is way cooler
-temp @ 8 is like 220 degrees vs. 500+ degrees on other headers
-I played with the timing a bit but didn't seem to change anything
Thoughts?
-compression check
- 150 psi
- 150 psi
- 150 psi
- 150 psi
- 150 psi
- 150 psi
- 150 psi
- 139 psi
-20 -22.5 psi
Thoughts?
