92 camaro, 383 stroker 10.5: compression edelbock performer rpm vortec manifold, short tube headers.4.56 lift int/ exh . a friend of mine got me a predator street carb for 50 bucks and i would like to use it. my only problem is not being able to run vacuum advance, unless i can figure a way to put a potentiomoter on the throttle arm i have noway of running a tps and therefore no way to run an electronic ignition. i was wondering if there is a way to create a ported vacuum source or if anyone makes a timing computer that creates a curve based on engine rpm and not sensor inputs. i have two distributors that i could use....the mechanical/ vac or the esc hei. i would like to use the esc, i know msd makes a timing computer, but i do not think it works with gm hei and it requires an msd ignition box, i would rather run a dui module so i can have a longer duration rather than an msd so i can run a wider gap. i havnt hooked an ignitionscope up to this motor because it is not running yet. but based on my other hei motor with a .065 gap i estimate that i can have a 3.5Kv firing line and a pretty long duration. it was a perfect burn and i do not want to spend the money on an msd box. ................. humm i might be able to get a ported vaccum source off of my exhaust i will try that
