POR 15 is something you would use to complement dipping and e coating. What POR 15 will do is keep the rust from coming back. Its a rock hard coating that seals the metal from the elements. Think of it as permanent primer. Don't use it as a finish coat on any surface that will see direct sunlight as its color won't hold up in ultraviolet light. Won't damage its anti rust capabilities any but the color will turn chalky. Great for frames and inside trunks etc.
Centerline
<a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</A>
Centerline
