1 - 8 of 8 Posts
im redoing my wifes car that is going to be a driver . i cant afford to dip or have car blasted .will that rust paint work in rust pits on body to keep from rusting through i a year or so or what shoud i do .moneys tight but she has cancer and i want car back on road as soon as possible ,was her 1st car .65gto
Huffed, some of those rust paints work some don't. there is some good stuff out there thats not to exspensive. I used to use a product I found in the front of a collecter car trader that worked great. Can't remember the name, but will keep looking.
Can you do bodywork? If not I am a body tech and would be happy to walk you through it step by step. send me an e-mail, tell me exactly what the problem is and I'll do everything I can to help
Faust
i've been using rust reformer for about 12 years, it was developed for oil rigs out in the oceansit works well. napa makes a product called rust preventive. about 7 bucks a bottle, it goes a long way. get all the loose scale out, brush or usea rag to put it on, let it dry, scuff it off with 100 grit sandpaer, skim coat with bondo, or primer and spot putty if it's not to bad. a good sealer primer will help keep it from coming back on you. good luck and a speedy recovery for your wife. dan
thanx guys .ive never used that rust stop stuff always cut rust out and replaced but car has too much rusty pitted spots to cut it all out and replace givin the time constrictions im workin with
Premium Member
Get a cheap sandblaster from Harbor Freight. They have one that is a nozzel/gun, hose and probe that sticks into a sack of 20 mesh sand from the lumber yard. Add a rental 3HP and for way under $50 you can clean your bad spots down to bare netal. This is the ONLY way you can be sure to avoid those ugly paint bubbles in the future. The rust stop paints work sometimes, sometimes they don't. Not worth the gamble when it is so cheap & easy to fix right.
I used paint stripper to get rid of all the old paint then rubbed it down with Navel Jelly which is a form of Posphuric (spelled wrong) acid. Then I sanded it and painted it with Zero Rust even over the pitted rust. Zero Rust really kills the rust it wont come back. Check it out at zerorust.com Later!
1 - 8 of 8 Posts
