I just bought a 1959 Rambler and there is some major rust through the floor boards. On the passenger side, there is a foot-long rust hole right below the firewall, and the firewall is also bad in places. I was wondering if I could just cut some steel and weld it to the firewall and have it bend down to the other good steel or if it would be better to have to adjoining plates? Also, I read to smooth it over w/ bondo or similar product. Would it be okay to just fill it in with weld and grind it smooth? IS it better to make a plate and cover the rust, or cut all of the rust out back into the good metal, and then just weld a plate even w/ the good metal? Also, on the driver's side, there is rust under the accelerator pedal. I have been told that this is a huge problem, but never why? Can I just weld a plate in there and drill a hole to fit the accelerator peg through? I have pics of this rust that I can send to someone. Any help would be greatly appreciated. Thanks!
-Levi
-Levi
