I have a 2000 chevy s10 that is a daily driver.I bought a set of 17 inch American racing torque thrust wheels with 255 55 17 tires from a friend. They rub a little bit if you turn the wheel all the way on the sway bar. Will a set of adaptors work or do they make a after market sway bar that will work.
THANKS
Premium Member
You can make a spacer plate.Start with a piece of 1/4'' alum.But you may have to get longer wheel studs..It may not take much to clear.You might not have to go with 1/4'' plate..Make it one piece. :)
