....So in short OEM vac.sw. (n.c.) im guessing will be connected to n.c. contacts of relay? And pressure sw. & soli. valve (n.o.) will be connected to the other contacts on relay.
Nope. The vacuum switch switches the relay's control (coil) circuit (terminals 85 and 86). The pressure switch and solenoid get their power from the relay's NC (87a) terminal.
In the diagram above:
Relay terminals 85 and 86 are the control circuit. If you power one and ground the other, it will trip the relay.
Relay terminals 30, 87, and 87a are where the work is done. Terminal 30 is known as the "common" terminal. When the relay is
not tripped, terminal 30 is internally connected through the relay's contacts to the 87a (NC - Normally Closed) terminal. When you 'trip' the relay, the 30 terminal's internal connection changes from the 87a to the 87 (NO - Normally Open) terminal.
In this case, fused key-on power is supplied to both the 30 and 86 terminals. The 85 terminal gets grounded when the normally closed vacuum switch senses vacuum less than 8 inHg. During this low vacuum condition, the relay is tripped, and sends power from the 30 terminal to the 87 (which isn't connected to anything). Meanwhile, the 87a terminal (which is connected to the trans switch) is dead.
When the vacuum increases to the point that the NC vacuum switch opens, the relay coil loses it's ground and the relay un-trips. When this happens, power supplied through the 30 terminal is passed to the 87a (NC) relay terminal, thus sending power to the transmission pressure switch. If the transmission pressure switch is also closed, power passes through it to the lockup solenoid, engaging it.
Hope that makes sense...
Good Luck :thumbup:
