Bcm
Wheels427 said:
I'm just finishing up my S10 350/350TH conversion, carbed motor.
I have eliminated the computer controls and now need to wire up the heater blower. I know the blower is supposed to run anytime the key is in the on position but I've never messed around with the controls that regulate blower speeds.
Can anyone shed a little light on wiring needed to get the blower running with all the various speeds? Schematics? Even random thoughts?
As it stands now I have power to the switch on the dash but don't know where to take it from there, I think it originally went to the computer. The truck is a 95 and yes, I need the AC to work also.
Thanks for any help anyone can provide
Its not the heat, its the stupidity
Wheels
Doc here,
imp:
It appears That your truck has a BCM (body control module) that controls the Heater / AC functions...
After looking through no less than 21 schematics for your truck, I can find NO reference to that module and it's terminations....It's like it was a state secret or something...But, this is where you need to isolate all the wires.From what I can determine the system works this way...:
Signal and power------->Switch------->BCM|--------->Heater Controls
|---------------------------------------------------->A/C Controls
You need to isolate the wires in/out of the BCM (when you locate it) and determine if they require low voltage Signal...Or power to bypass them.
If you STILL are using the BCM, Use Care, General Misery Warns about using ESD equipment (Electronic Spark Discharge) Tools around These circuits & Switches..as they can render permanent Damage to the system..
I assume because (the big state secret box) BCM has MOS or CMOS chips inside of it, where a static discharge from hands, clothes tools, can blow a micro hole through the chip substrate..
I can tell you that the Heater / AC motor has the resistor mounted on the outside (Firewall side) of the plastic shroud, plugs in like a fuse , and is held in place by one screw at or near the motor plug....(if that helps at all..)
Best bet is locate that BCM and backtrack the wires...
If you removed the computer PTM (powertrain module) The BCM MAY still be in operation..as all the wires I could locate were inputs to the module, not power or grounds...but low signals...And if I determined correctly , lots of other stuff would be inop if it were not at least partially working, like lighting, warning lamps and buzzers, wiper speed controls, Air Bags ...and the like...So If I had to -->*Guesstimate*<-- That module SHOULD at least be partially operational..
If you wanted to you COULD abandon the Harness for the system for heating and air and wire it straight for Non computerized (as mentioned before) But the task would be massive as you would have to analog wire things like vent doors, zone temp sensors, Compressor Clutch relay (s) ,Panel switching, and limits, and speed sensors..
I would research the library reference desk or try a haynes or chilton for a diagram that INCLUDES the BCM schematic and attempt repair in that direction..before going the other way..
Sorry I couldn't be more help..
Doc
imp:
