I am painting an engine compartment piece with single stage black that I am also clearcoating. Ive used 3 wet coats of single stage black and then two coats of high solids clear. Ive let the clear dry for 24 hours (70-80 deg). Then Ive wet sanded with 600 grit, then used a 3M finishing film disc of 800 grit. Then a 3M finishing film disc of 1200 grit and then a piece of Norton wet paper at 1500 grit. I then polished with a wool pad using Meguiers #105.
I realize I need to do a couple more steps of polishing but teh visible sanding scratches are quite noticeable and when you look close up at the polished area the sanding scratches are plainly visible. I think they are some of the 600 wet scratches still showing through.
I went and isolated a seperate area on the same part and went through my sanding steps again taking more care with each grit to get a thourough sanding and polish with Meguiers #105......still the same visible scratches.
Any ideas on where I might have gone wrong or what I can do to make sure the sand scratches are removed.? This is seriously frustrating.
