they went from leaded to unleaded gasoline, and under there current technology and research had to go from 10.5-11.5:1 engines to 8.0:1 engines and in turn also took the lift and durations out of the cams, takeing the power down to horrible #'s, you should look for a set of chevy vortec heads 062's are the best as they have a better exhaust seat and allow better flow, but the 906's are a very good head to they are 64cc instead of 76cc combustion chamber this alone will raise you compression ration up by a full point getting you to that 9.0:1 number your looking for, they also have a larger int valve, and runners to increase flow, these head are one of gm's best flowing production heads ever made for the sbc, you will need to run a vortec style intake but im sure you could find a decent performer/or perf rpm intake with the vortec bolt pattern on craigslist or e-bay for cheap, then buy a 600-650 cfm carb, a mild cam, and you will increase hp/tq#'s by at least 100
