That is a race cam, looks like a lift and or duration limited class. The 106 LSA makes it unworkable off the track because it cranks the overlap way too high. This is good if you keep the revs in a range of 5000 to 6000 but is a dog under 5k. More stall will not help.
To make matters worse such a cam will need very good heads and a static compression ratio of 10 or 11 to 1 to make any decent bottom end.
I still wouldn’t eliminate the possibility it’s not timed up with the crank either. The easy start and poor everything after that is the hook I’m hanging my hat on about how it runs. A big cam would steadily get better once about 3000 rpm and would start to paste you in the seat by 4000. I will repeat that timing the ignition to the crank is NOT the same as timing the cam to the crank. The only place that happens is with the cam drive mechanism inside the timing case. Ignition timing to crank is completely independent of that, as far as the distributor is concerned the cam is just a jack shaft transferring rotary motion from some source, in this case the timing set, the distributor would be just as happy if the cam had no lobes on it as the activity of timing the ignition to the crank would be the same. All the designers are doing here is getting the cam to do two (2) separate jobs with one part.
