Well some of you may have followed my ordeal with the oil consumtion of my 383. After 1000 miles on a fresh rebuild (#1) it went to the shop for a complete rebuild. There is 500 miles on the new rebuild (#2) and I am having exactly the same oil consumption issues despite the bores being checked and the correct hone being done. Looking at my records after an oil change (oil black contaminated by blowby) it looks like I used 6 qts give or take in 500 miles and I just talked to the builder (he is going to troubleshoot...leakdown test, cold and hot compression etc) but off the top of his head he is puzzled and never had a problem like this. His guess is I have a bad block casting and experiencing cylinder wall distortion when the block heats up. It is bored 040 over. Without further troubleshooting looks like I may need a new block to swap over the top end and rotating assembly to.
I guess ideally block should of been sent out and paid the $80 to get sonic tested.
Also I was researching the casting 3932386 1969 4 bolt 350, 2 bolt 327 or 4 bolt 302. Originally I was led to believe it was the 4 bolt 350 and when my builder told me it was only 2 bolt I did not think much of it until now I realize it originally was a 327. Since it is 040 over and stroked is their any difference between an equivalent 350 block ?
