Got a little problem and wonder if anyone else has ever run into this and converted over an alternator bracket made for another application?
Putting a 350 Chevy into my '39 Chevy (swapping a newer one in for an older one)....Have a long water pump and want to keep my alternator bracket on the driver side with a high mount (not much engine bay room for a mid or low mount)...the one off my old engine is not desirable to reuse.
The problem is: for whatever reason, there are very few brackets on the market that are "driver side/long water pump" applications....(there's a ton of them for short water pump and passenger side.) The ones that are available (for the long water pump) are pretty expensive....yet alot of the "short water pump" ones are relatively cheap.
For my own reasons I wanna keep the long water pump so....I'm wondering if anybody out there has some personal experience with taking any particular brand name alternator bracket made for a short water pump and converting it to use with the long water pump/driver side setup?
Thanks very much if anybody has run into this same situation and found a cheaper alternative to share.
