Hey Guys,
I recently dropped my SBC into my boat. It is a fresh rebuild with new vortec heads, Crane Cam, new lifters, primed oil pump, little gas in the carb and what I thought to be a little advance timing. Hooked everything up and tried cranking it over. When I crank it over, it wont start up, but tries to. At the end of one crank session it backfired pretty bad through the carb. I thought maybe I was 180 out. I tried adjusting the distributor 180 degrees from the point it was at at when i stopped cranking. Same same, backfired again, this time with a slight "wooooopmp" along with the small pillar of flameage. When I initially set the timing, the cam was set to fire at 6. I aligned the cam and crank dots, and set the distributor to fire at 6 on the cap. Does anyone have any insight? I am about to drop the stupid boat off at a mechanic and let him figure it out (I deploy in 3 weeks and I am tired of fiddling with this thing, I want to get out on the water.) Thanks for the help guys!
