Ayuh,.... That castin' number could be a 302, 327, or 350....it would have to be the only 350 on that list. this 4 inch bore block was not used on 307s and 305s
Your title lists the casting number as 3970010, if this is indeed an 010 casting it is the highly desireable heavy duty 4 inch bore block that was used for some 302's and 327's and a ton of 350's. It was used as a basis for high performance passenger car engines as well as heavy duty trucks and industrial engines. It is found as 2 or 4 bolt mains, the only way to know is to pull the pan. 2 bolts are good and 4 bolts gooder. If a two bolt this block easily converts to 4 if that much strength is needed. It is of course a 2 piece rear seal and has no factory provisions for a roller cam.it could be a 350, 327,305
vin # ko126tbm :sweat:
c97155985
