Just out of curiosity what is your cam specs and rest of your engine build? I have a Trick flow/Edelbrock RPM air gap intake and I am having some werid fuel distribution issues and my worst two cylinders are the two front cylinders that will foul out in very short time and it gets lesser as the cylinders going back and no amount of carb change and calibration and even using different carbs is getting rid of the problem.
All things have been checked on mine such as the ignition system along with valve train and other stuff and mines a new build. Mine starts off super foul rich the two front cylinders and then slightly lesser on numbers 2 and 4 then lesser yet on 5 and 6 and the leanest on 7 and 8. By going through my firing order when it fires on number one it will be pig rich and then on number eight it will fire way leaner. Mine is so weird that in believe it or not I had it out the other day in 20 degree weather with the wind chill at near zero and for some abnormal reason it ran the best it has ever been since I had started to trouble shoot the problem. I have another posts elsewhere that you might want to read up on and it might help shed some light on your issue and maybe you have a similar problem like I have but I don't know as I have not gotten my dialed down yet but it comes down to the intake not liking my camshaft specs for some reason.
I am from Ohio so it gets really cold up here but I used an air gap intake before with a bigger sized cam and all year around and never had any problems. I tried different spacers and it had a really abnormal effect and something is going on with my intake and the signal its getting and the air fuel ratio is some how going all over the place up and down depending on throttle position and certain driving factors. I am getting ready to replace my intake with a non air gap and see how it does. I have always used a four hole spacer with a dual plane and it always worked excellent on any of my builds from mild to wild without any ill effects. Good luck on your quest and hope you find out what the problem is.
Hey there . I live in uk , so temps range between 5c & 30c in the summer so never as extreme as you get I the states.
My engine specs are as follows :
Sbc gen1
+40 bore flat top pistons
Edelbrock e Street heads
9.5.1 compression
Howards roller cam conversion
280/288 lift .525/.530
Comp cams ultra gold 1.5 roller rockers
Dart shp dual plane Air gap manifold
Holley 670 Street avenger carb with 68/70 jets
2" 4 port carb spacer
Performance hei dizzy
1/34 medium lengh headers in to dual 2.5 pipes
Guessing about 400hp so not a crazy spec motor.
