Well, not to be picky, but the first-get SBC is still in production. Its available in medium duty trucks, vans, and in many other countries, not to mention all of the industrial and marine applications. I have an Gen1 Vortec intake that was pulled from a 2002 Chevy Van.
But the generations typically go like this
Gen1 is traditional SBC. 2-piece rear main seal until 85 with a flat tappet cam, 1-piece rear and roller carm 86-present with exceptions to the roller cam rule in trucks. Perimeter valve cover bolts until 86, centerbolt covers 87-present. Along with the 1-piece rear change came an intake manifold bolt change through 95. 96-present is the vortec style which is a whole different intake bolt pattern.
Gen2 is LT1, LT4, and L99 engines. They share some things in common with the older Gen1. Rotation parts are pretty interchangeable with Gen1 with slight differences in cam drive. You can always tell these motors apart because of the long intake plenum, and the water pump has no pulley since its internaly driven. These motors were 92 (a few showed up in 91) through 1997.
Gen3 is LS1, LS2, LS6, and the LS-based truck engines starting in 1998. They didn't make their way into trucks until 99 or 00 but I'm a little hazy there.
