Im putting a SBC in my Ford 9N tractor.
(temporarily using an old block that we use as a weight on our disc)
As it turns out, the small block actually fits NEAR perfectly between the tranny and the front axle support.
That is.... IF i can populate the front of the engine with a short enough accessory drive assembly.
I will only be running a crank pulley, water pump, and alt.
It looks like I have 6.75" inches between the front face of the block and the rear of the
radiator. I can fudge a bit more out of it if i have too.
Thats where my question comes in. Is that doable?
If so, is there an existing drive assembly I could use that would fit within this envelope?
As far as I recall, theres a long and short waterpump for the sbc. But I dont have a shorty on hand to measure, and since theres always wild and crazy stuff coming out for the sbc's, I thought i would ask just incase theres something out there i dont know about.
The engine is a 305 (suffix code DDL).
The reason im trying first, to fit this within the stock envelope of the tractor, is so I dont have to lengthen the hood.
Thanks in advance.
UPDATE I over looked the front axle to crank clearance. Not doable without lengthening the tractor. Which I will do. ***
Thanks in advance.
