Whatever you do. Don't throw money at it. That's guaranteed to make things way worse. Unless you're like me and hoping for an excuse to spend 3 or 4 grand on an aftermarket big block block. In that case. Yes. Throw the money.
410 gear. Trucks light in the back, probably go up in smoke, but, sounds like what your looking forHi,
I am hoping someone can help shed some light on my current set-up. I know this has been raised a lot on here before but I couldn’t find anything that really gave me an answer.
I have only just got my 66 C10 with a 350 on the road and it feels like a bit of a slug/like it is still a stock motor (before all the upgrades happended). I have measured the 0-100 and its around 10 seconds (shifting manually on the TH350) which is slower than my 1.2 litre Volkswagen Polo and from a rough calculation would equal around 150 hp at best. The engine is as follows:
- Stock bottom end – standard bore and compression test is all within 4% of each other
- New alloy heads with 195cc runners, 64cc chambers 2.02 intake and 1.60 exhaust which are a little big but looking to go a 383 in the future. Flow numbers are:
- Lift Intake Exhaust
200 145 106
300 192 135
400 232 160
450 242 168
500 242 178- XE262h cam – Was a comp cams kit with timing chain, lifters and springs
- Edelbrockperformer RPM intake
- Brawler 650 carb (brand new) vac secondaries
- Flowtechheaders – 1 ½ primary, 3 in collector but runs a duel 2 ¼ in exhaust to Flowmasterstraight through mufflers
- MSD StreetfireHEI distributer – new MSD leads and spark plugs
- Initial timing is set at 14 degrees and total 34 degrees (all in by 2800 rpm)
- Stock TH350
- Stock Converter
- Rear gear ratio 3.73
- Rear tire height is 28 inches
The car starts, idles and cruises perfectly and sounds strong but just doesn’t seem to have much go at all. The plugs are not fouling or over rich or lean. My question is whether I am just expecting tomuch out of the engine (although looking at the dyno sheets from comp cams for the cam I am not) or whether it sounds like something is a misssomewhere? While I feel like it would benefit from a looser converter I don’t feel like this would change the accelationthat much.
I have ordered a cam degree kit to check whether it has been installed retarded and is the correct cam. No loose lifter and pushrods spin when cranking so don’t think I have wiped a lobe.
Hopefully I have provided enough info for someone who knows more then me.
Thanks,
Jamie
Ask him to give you the engine serial numberIf you’re going to a 383 in the future I say your just stuck till that happens.
When you say it’s a stock and apparently will used bottom end I’d hazard to guess that the botton end is tired. Obviously a 66 C10 predates a 350 being the original engine, so it’s something from somewhere else. 350’s from the factory cam in variations from 170ish horsepower to 375, there is a lot of difference in the Potomac ends of these engines. The thing most affecting power of these engines is the combination of cam and compression.
So without knowing exactly what version of 350 is installed in this truck nor its condition relative to ring sealing, blowby, oil consumption and how the details of your top end rebuild in terms of exact head used more specifically chamber volume, the thickness of the head gasket used and you must have seen the pistons so can deliver some insite as to what is the crown shape of the pistons. Basically the average 350 will be low compression, not every 350 is a Corvette as the popular press would lead you to believe, so there will be a round dished piston with 4 valve reliefs. A flat top with 2 or 4 valve reliefs perhaps even a small pop up dome would be a high compression piston.
In normal factory builds even with the more typical 64cc chamber iron head these would use a fairly thin shim gasket. If you installed aluminum heads with the recommended thick composite gasket you lost compression ratio. Added to that aluminum pull heat out of the burn faster than iron. Heat and pressure walk together through the Gas Laws. So here you get a double whammy of lower compression generating less heat therefore pressure thus less force on the piston.
Changing to aluminum heads and adding cam is not a guaranty of adding power. The Devil is in the damn details of how good the original bottom end is at holding compression and combustion pressure, ie are the rings and cylinder walls any good. What compression did you start with therefore we need to know the original head, they have a casting number between valve spring sets. The original head gasket and what the piston crown looks like from this we can determine pretty closely the original compression ratio. This then extends into the heads you put on and their chamber size and what thickness head gasket you used so we can calculate the new compression ratio.
This is not to say the carb or the ignition is not yet tuned adaquatly nor even if the cam is timed correctly. I’m trying to understand the physical constraints of the build to get an idea as to whether proper tune could ebven make a difference if there are oddities about the basic build which are not all that uncommon an event.
Yeah, if that won't spin the tires on a pickup, something is way off. I am surprised it starts and runs well if timing is very far off. But that is where, I would begin. I might try to stop the secondaries from opening as well. To test if the carb is just going stupid lean, but then it might also spit back through the carb. I would be curious to run a compression check as well, it could offer up a clue.Thanks for all the replies fellas.
-Bogie you raise some points that are valid and I know they are not ideal but low RPM should be better. I never realized a tranny could be that big of a parasitic drag. There are definitely some things to try but want to try to cross off everything I can before dumping money or pulling heads off.
- Poncho it’s 0-100km so 0-60 miles sorry.
- 75gmck25 that was my estimate based the cam and parts. I think I need to recheck the damper to ensure it hasn’t spun at all. Also have to get an AF gauge to check things. Although I wouldn’t think carb tune would be around 200hp. Especially when it runs smoothly with no smoke.
- curtis73 it is possible. Looking JE pistons site even that low of compression or 1 point is 4-6% still doesn’t account for the massive power such. I am sure the secondaries are opening, I can hear them sucking, although I might have to stick a paper clip on the secondary pump to check by how much.
-johnsongrass1 the rear gear is 3.73.
-Mousecountry I am not sure what you mean by post your tune up specs. The initial timing is currently set at 14 and 34 total by 2800. I haven’t touched the carb yet as the plugs are telling me it in the ballpark and it starts, idles and drives perfectly. Just a slug.
Rustbucket- I know, the tires are only 6 inch wide and I couldn’t get them to spin at all. As stated previously, I think I need to check the damper hasn’t spun and that TDC is indeed TDC.
I don’t get to work on it except on weekends so will let you know my findings.
Thanks again.
My set up is close to what you have and my 1970 Nova runs 13 in the Quarter mile. Check your Air/Fuel and timing. If that's not it you have trans Issues. I had the same problem with another car changed out the trans and it was a night and day Difference. It then layed down some nice rubber on the road.Thanks for the reply gents.
I will get the block number, I have looked it up before and it’s out either a 62 truck or 80 truck. Both were turds looking at the power numbers. However, the pistons are not the 4 valve relief dish ones. They have a slight dish with no valve relief like the magnum 360 ones. Heads are 64cc and head gasket is 0.38 compressed thickness. NOT great compression but still shouldn’t kill it that bad.
I have ordered an air/fuel ratio gauge to check the carb and tuning. But I think Curtis may have nailed it. That is the sound I can hear at WOT! It’s a pretty distinctive sound that I have never heard. I bit like a turbo blow off valve. I will see if I can get a video. I guess I would drive, go wide open and then check the plugs and they would darken in the time that I went WOT the back to the garage so was thinking all was in the ball park. That’s why you need an Air/fuel gauge.
Bogie nailed it as usual.You don't need an AFR gauge, although it is helpful. You don't need a different engine. It will make the power just fine if you tune it right. It doesn't even have to be "right" as long as its working
Not sure what that means.Bogie nailed it as usual.
The man knows of which he speaksNot sure what that means.
