When you are running a solid lifter cam. Do you remove any of the oil valley plugs at the front of the block above the timing chain cover? Just wondering what the thoughts are on this topic across forum.
Bowtie man said:When you are running a solid lifter cam. Do you remove any of the oil valley plugs at the front of the block above the timing chain cover? Just wondering what the thoughts are on this topic across forum.
I think massive oil leak = no oil pressureOriginally Posted by Bowtie man
Bowtie man said:The plugs are on the inside of the timing chain cover it would result in more oil getting back in the pan quicker.
Sometimes an engine w/a solid or roller cam along w/roller rockers will use oil restrictors in the oil gallery. This is prob. what you are referring to.Bowtie man said:When you are running a solid lifter cam. Do you remove any of the oil valley plugs at the front of the block above the timing chain cover? Just wondering what the thoughts are on this topic across forum.
No, this would result in a pressure leak to the pan with a large, if not complete, loss of pressure in the lubrication system.Bowtie man said:When you are running a solid lifter cam. Do you remove any of the oil valley plugs at the front of the block above the timing chain cover? Just wondering what the thoughts are on this topic across forum.
