Theres a chance I may be able to get my hands on a pair of edelbrock rpm heads for similar money to my building up a pair or rhs pro torkers,
but wanted to know if they will work with my motor?
the heads are the performer rpm 6073 64cc heads.
the engine is a 2 bolt mains 357
new cast iron eagle crank
speed pro hypertectic flat top pistons 4v reliefs
Performer plus cam.
performer inlet manifold
tube headers
600cfm holley
I had been building engine on the assumption of 300hp with the pro torker 12402 heads 67cc chambers giving a static compression ratio of around 9.5.1
but running the sums the 64cc rpms would up it to around 10.1.1 static c/r
Do you think I will encounter problems with piston to valve clearance?
would that small cam run ok with the heads? not to bothered if not making full potential as can always upgrade at later date, or will i need to change this out?
Performer plus cam.
tube headers
600cfm holley
