First time swapping out a sbc timing chain set... '84 SBC 305...
I'm down to installing the new set, but due to timing setting inspection, and not realizing it, I turned over the crankshaft without the timing gears in and don't know if the crankshaft is on TDC anymore.
The camshaft is at TDC, was at #1 TDC (Both timing gear dots up at the noon position), rotor points at cylinder #1, and both valves are up (closed)...on compression stroke.
How can I realign the crankshaft back to TDC ?
