Are the original SBC twisted wedge heads with the tilted inlet valve worth investing in?
I plan on putting them on a 383 that I'll be putting together..
Or should I just from the beginning on invest in a new set of heads, like new TFS or AFR?
Will the old ones provide as much power as the newer ones?
If the angled intake valve was a good idea, how come it is not made anymore???
Thx :)
King of my Man-cave.
I have a set of the original SBC Twisted Wedge heads in the shop now. While I think the idea of the tilted intake valve had promise, I don't think it panned out as well as was hoped. To take advantage of the heads, different pistons were needed and I don't think the advantage was worth the cost of designing and producing them. In other words, There just wasn't enough gain over well-designed "normal" heads.
tom
lluciano77 said:
What do you think about the Twisted Wedge SBF heads?
My guess would be that they are probably more successful than the SBC heads. Perhaps it's because there is a little less competition in the Ford head arena. Somebody with a flow bench could check it out.
tom
so, I would also need a set of matched pistons....
I think that I'll stick to the newer heads..., which doesn't need special pistons...
Thanks!
