1 - 6 of 6 Posts
Hey...
New member here...
I have a 69 Camaro that was used for drag racing before it came to be mine. So nothing on the car is "sacred" in terms of matching numbers, etc. I've been slowly doing things to put the car on the road, started out replacing all the ball joints (3 were original) and doing brakes. Next, had the upper rear shock mounts redone, as the areas were pretty crappy. I had the 456's replaced with some 373's so you can actually drive it instead of using it to pull stumps with.
Now, I'm starting to look at the interior. The car has a set of Mopar seats in it, which arent really comfortable, and don't look like much either. I'd like to replace them, but I'm not sure what with? Are there guidelines regarding what WILL fit and what won't?
Btw...I'm pretty new at working on the Camaro, but I do know which end of a wrench to hold...
Jim
Shop Owner And Troll Hunter
The old camaro seats arn`t very comfortable. I have a custom camaro, with 94 honda seats bolt right in,drill one hole.
where are you? i have a set of seats from a 99 chevy malibu i'm considering parting with for cheap in a neutral beige. its the front bucket seats and the rear bench with seat belts. i'm not sure how they fit in a 69 though.
Don`t know about those buckets, the rear will not fit.
Seats for 69
I've seen quite a few guys fitting their cars with newer model Camaro/Firebird power buckets.....bolt right in. I've also seen a couple where they worked the rear leather seats in too. Very nice. I'm planning to do the switch mysefl in my 69 Bird.
1 - 6 of 6 Posts
