I recently purchased pair of Sebring Seats for my 64 Ford from my local pic-a-part. Up until now, I did not know that there was a module that I needed which I did not get! With first generation I believe when the solenoids are powered, the seatbelt can be moved. When the solenoids are not powered, the seatbelts cannot be moved.
http://www.corvairkid.com/sebring.htm
I think my seats are 2nd generation. I am able to move the belts on both driver and passenger side with no power connected. When I can jerk the seat belt, they seem to lock fine without any module. From what I found so far, beginning with the 2001 model year, the Seatbelt Control Timer Module (SCTM) was eliminated and the electronics were fully integrated with the airbag controls into a unified occupant restraint system. The seats do have pyrotechnic pre-tensioners which I have left disconnected.
It appears that the module with 2001+ seats only controls the pyrotechnic pre-tensioners in the seat itself + the air bags.
Does anyone know even if I get the module, it will not work without all of the impact sensors and stuff. Correct?
Is there any issue with my seat (2001+) operating properly without the module & leaving pyrotechnic pre-tensioners disconnected?
Can I replace the pyrotechnic pre-tensioners with 1996-1997?
waid
Thanks
waid
Thanks
