AFter having taken a break from here..
I'm looking for info on the Holley 750 Double Pumper carburetors. I'm changing from a Rochester Qjet setup.
Specifically the 3310, 4150, 4160, and 4779.
I need to know which one is the best for my set up.
And weather I should add the Holley 112-96 base plate to it
I use a Edelbrock Performer manifuld.
I see a lot of 3310-3's around. Although I can get 3310-2 and 3310-4 pretty easy too. I don't know the specs of the 4779. Then theres the 0-80508 carb.
The engine I have it on right now is a pretty well built 350 with common parts. Normal every day pump gas is what I'm using.
Help picking out which carb I should use would help.
Thanks,
Greg
Thanks,
Greg
