I am planning to fabricate my own gas tank for my hot rod. Does anyone know where I can obtain a weld-on or bolt-on sending unit flange?
It depends on the type of sending unit you are planning on using..........
I know that Stewart Warner makes them for their sending units. I got one and re drilled it to fit my 40 Ford original sending unit hole and turned it into a bolt on adapter...................so I can use a SW gas gauge.
SpeedWay out of Lincoln Neb. has them.
:thumbup:
I suspect your building a Ford but if you're using aftermarket gages that are compatable with GM style fuel senders then Summit Racing has this inexpensive sending unit.
Centerline
