Sequel Corp Remanufactured 454 Question
Hello Guys
I recently purchased an excellent running 454 that was in a '73 1 ton Chevy PU. Engine ran great (no smoke, good oil pressure) in the truck - the only issue was a slight lifter (or exhaust?) tick on the pass side.
I bought & pulled the engine & brought it home. The block casting number is 361959. There is a number on the front pad, but no suffix. The block casting date is 1978 - 346236 casting (peanut) heads.
When I pulled the engine I noticed that the Quadrajet was a remanufactured carb with a 2006 dated tag.
Tonight I noticed that there is a metal tag epoxied to the lower driver's side of the block. The tag reads: Sequel Corp.. Ser# 4196938XXX over FDSCV454TCP. A google search reveals that Sequel Corp is an engine remanufacturer located in Missouri, but little else.
I bought this engine as a rebuildable core - I plan on changing the pistons, heads, cam & lifters (solids) in order to make a high compression HP street/strip engine that will see 5500-6000RPM tops.
Does anyone have experience or knowledge of this Sequel Corp?
Do they do a good job rebuilding, or are they a half azzed organization?
I'l find out the ugly truth when I tear the engine down - I'mm just looking for a little background.
Thanks!
Wildman1
Hello Guys
Thanks!
Wildman1
